Starting out - Thanks Teet
Originally posted by Teet. Don't thank me for this.
well , you can do as i do and just hit the highest nw on and go from there.
i.e - 1/9 4:04pm KiroDies... HI $6,890,711 [View]
my nw now - $6,897,232
went from $7,000 to 6.8mil in 1 hit.
but yes , i did write a bible a couple of years ago. all of the #s still work especially if you are wanting to start out as i do you will need to use a bigger #.
And Teets Almighty Bible: Midnite Challenge Bible
Let's start with HI, CJ, and Stealing Cars:
HI #s
racing - 154/221 , 152/233 , 235/360 , 135/231 , 122/233
tuning - 154/221 , 152/233 , 235/360 , 235/369 , 122/188
prowling - 235/360 , 235/369 , 154/231 , 120/230
home online & offline - 133/233 , 235/369 ,120/120 ,122/232 , 141/220 , 153/233 , 237/143, 150/130
CJ
144 , 149 , 197 , 202 , 210 , 215 , 222 , 403 - there is no real timing in CJ'n. Just try #s until you hit. I like to do 149 , then 202 , then 144. if you miss after 5 tries , move onto someone else. you can always use 403. its a big # , but works better than other other #.
Stealing Cars
Stealing cars:
w/o alarm or low leval it is:
101/114
85/115
120/121
104/108
expensive cars with full alarm:
235/360
ok , online HIs:
say your nw is 2mil , your ideal target would be someone with a nw no more than 10mil. if your nw is 10mil or more ,the sky is the limit. its easiest to hit someone no more than 10mil over you , but possible for anyhting if your skill lvl is high enough. the higher your lvl , the better. 19 is a great lvl to HI at. anything higher is even better. never try and HI below you , its possible , but thats information ill never give out b/c only me and 1 other person can do it.
ok , say a guy is online racing and in your HI range. first put in 154/221 , if you miss , hit back and use 152/233 , if you miss , hit back and use 235/360 , if you miss , use 135/231. if you miss with all of those , move on to someone else. nw does matter. ive gotten 17 HIs in 1 day before , but ive also gone all night w/o 1. getting down the right nw helps alot. thats somehting you will learn to judge in time. just pay attention to what your nw is and what their nw is when you hit them. figure the diff and log it. then try again on someone the same nw diff. keep the same stradegy.
ok , the daddy of all , At Home HIs:
nw diff is the same for offline as it is with online. finding the right nw diff is important. if my nw is below 10mil , i dont try anyone 13-14mil over me. if your nw is 15mil or higher , try to go for someone 17-19mil above you. ok , first put in 133/233 , if you miss , hit back and use 235/369 , if you miss again , wait anywhere from 3-8 sec and use 133/233 or 235/369. Timing is diffrent for everyone. it takes practice to find yours. 133/233 works best for online at homes and 235/369 for offline at homes. if you miss with all of this , sign out and sign back in and try someone else. wait 5 min before you try someone else though. usually if you miss someone , try someone about 2mil under the guy you just tried.
Timing Cont.
also , watch the game countdown clock. I hit best when the seconds are between :58-:50 , :26-:20 , or :08-:00.
***im adding to this as i go , so it might not be in order. when i think of stuff , ive been just adding the info as i go***
i know some of you have heard about the 15min timing thing , it is bullshit. you can HI any hour of the day with the write # and write timing. when you do HI someone you can hit back and try again , about %60 of the time , it will let you HI the same person again. wait about 5-8 sec. also , if you hit on the 1st or 2nd try , log out , sign back in and wait 2 min. 90% of the time you can hit the same person within 2 tries again. if it works , sign out , back in and wait 1 min and try again. if you are trying to HI someone and you miss like 4 times. stop and wait about 30 min and try again. DONT FORCE AN HI.
side note - i can tell you everything there is to know about this game , but it is diffrent for everyone. i have helped many people in this game and given them the same info im giving you. it works for them , but they do change the # sequence and things like that to their liking. if this doesnt work for some reason, change up the # sequence. sometimes you might want to try 3 #s , then sign out and back in and try again. just play with it. it does take practice , but you will get it.
Working
This section is for the non-HIer's..
*****IMPORTANT - your win/lose ratio determines how happy your models will be. 0.61 is perfect. your models wont get too happy to where you cant recruit more , but they will get happy enough when it comes to working them.
When the game starts and you have 5k br , its hard to get started. what i do is cruise w/o a car for about 200 credits , then again for 100. after that , it will tell you that you need to raise your pf. you should get about 120 models. work them a few times and get alittle nw. then buy a car and buy a few PF parts (boom system , headlights , whatever) , then cruise for more models. you can keep cruisin w/o a car , but you will have to lose some models before it will ;et you get more. the more models you have and the happier they are , the less models you will get when you cruise.
Ok , once you hit about 30k , or close to it , buy a 96 land rover. this car gives the most PF. with 160k br , you can buy all the parts and have a 862PF with all the right parts. then cruise for 10 credits at a time over and over and you will get arounbd 34-37 models for every 10 you cruise. just put in 10 , and keep clicking cruise, dont let the next page load. do the math to determine how many clicks to do for 1k models (1 click = 35models) stop at 1k models though b/c it will tell you to raise your PF after you hit 1k. just keep working that until you get enough nw to where you can start recruiting.
once you have a nice nw , around 20mil or so , maybe less , get someone to cruise on their account for you and just recruit from them. have them buy a rover and just cruise over and over. i use about 60k per recruit ,you get about 100 models , depending on how happy yours and his are. again , just put in 60k and keep clicking recruit. you can get about 18k models with 4500 credits. as they cruise , recruit from them. just make sure you keep sending them races every 4 min so they dont get CJ'd (you cant get CJ'd if you have a race pending). at a low nw like 10-20mil nw , you can make about 15mil nw with 1k creidts. try and get them as happy as possible. the happier they are , the more money they will make for you. as you race the person you are recruiting from (the person cruisin for you) , your model happiness with go up and down alittle (about 5% a race) make sure you stop racing on the race that makes it go UP 5%. after you get your models , sign out and have someone race you offline and you win. usually your models jump about 10% when you win an offline race.
after you get your models to ATLEAST 80% , 75% will do , the like i said , the happier the better , work 1k , if they stay ,sign out and sign back in. then recruit from someone another 300 models or so , then work 1k twice. put in 1000 and click work twice. if they stay , log out , back in , recruit another 200 or so and do the 2 click thing. keep doing this until they leave. with a .61 w/l ratio , you should be abel to get atleast 6k credits worth or works. if they are like 90% happy , you can get alot more. ive gotten 10 works with 15k models when they were 90% and made almost 300mil.
Tuning from the best tuner in the game , Pussy (drunk2003)
This will work for version 1.3e:
Most of you must have noticed that everyone has the same car. Fastest cars are now low weight rear drive cars. That is the MRS in this game. I could tell you what parts to use, but maybe the parts will change, so you better know how to figure out the best parts. So how to start; PR is very important, so how to get the max pr out of your car. You need a supercharger and nos. Instead of a sc you could also take a turbo, that gives less pr but is about as fast on the track. Best way to figure out the parts is to build it when it's not fully upgraded, that would make it too expensive when you make an error, so always setup your car without upgrades for boost nitro etc. You could however buy security levels at this point to prevent your carefully tuned machine being stolen. Instal a part you think is best, then go to your garage and check PR, usually it is not 100% so you have to devide the actual PR with the % that is behind. So PR 200 (75) will have a 100% PR @ 200/0.75 = 266.66. When you install SC A and it gives you 210 (0,80%) and install SC b that gives 175 (60%) SC b is the faster part (175/0,60 = 291.67 and 210/0,80 = 262.5). This you can do to all parts. Just see what gives you most PR.
For handling just look at the handling rate when it goes up when you install it, same as pimp. Some parts give better handling but less pimp, it's up to you what you prefer. I would say f$%ck pimp cause it's better to steal models anyway.
OK, now that we have setup a car with most PR, we can go to dyno. remember, the car still isnt upgraded for boost nitro etc. For dyno, we all have sc and turbocharged cars, so we have to set them up at the dot under the 12.5. So first try to line them all up under there. so when they all are under the 12.5 add 1 to ALL and do that until every single line jumps one dot. If a line jumps, don't change that line and continue with the other lines. In the end you will have them all off by one dot. then substract 2 from all lines and they will be exactly right. Usually, that doesn't give you 100% PR , that's when the sparkplug plays it's part. Just change it by lowering the spark by 2 . You can change your interval with changes of one when you are close. This way you will be able to get it to 100%. Sometimes the spark plug has to be that low, that you can't get 100%, you can lower the spark to 22 if needed, the minimum of 26 is not correct. Even then it could happen that you won't get 100%. then it's up to you if you stick with 99.9% or sell that SC and nitro and install new ones. Then you would have to dynotune all over again but you will be able to get to 100%. If spark is [censored] up, I usually don't do that, only for WWWIII I would make 100%.
OK, when your car is 100% you could upgrade it in the tunershop to the maximum. when you do that just click all lines and hit enter, hit back to continue with next upgrade. After you have done that, you go to dyno once more and click the button once, that will give you your 100% back
Let's TestNTune.
You can read all tutorials you want, but you only have to look at the 60ft time. Just do it box by box. So, to start, go to box one and add 2 to the number or lower it by two. Check what gives you a lower 60ft and go in the direction which is faster. You will notice that at a certain point it will go slower again, then it's time to fine tune. just up or lower the number in the box by one to see the lowest 60ft time. Usually when the best setting is at 33 32 and 34 will give about the
same 60ft and 33 will have the fastest. Do that to all lines, but camber, the last box is 0 anyway. Maybe they will change that in future games you could try that out.
After you have done this your car will be [censored] fast, only pink with your car though when you can afford it and remeber to copy and paste your garage to notepad and save it in case you lose a pink race or your car got stolen by the thieves trained by teet
Status
Please be sure to click "Log Out" in the top right hand corner of you screen. if you just click the "x" , you will stay in the status you were last logged in as.
Crews
I have been in the winning crew for 5 sessions now. why? b/c we stick together. a great crew consist of theifs and workers. the way it is setup now , you need to get a couple top guys in your crew b/c they are the ones who are gonna work the most. i have ran with the best people and we have always stuck together. get to know someone before you invite them to your crew. they could just be there to hurt you. friends are hard to find in this game, but there are alot of good people in this game. just win as many races as possible to get crew models. keep your car tuned and only race people who you know you can beat. also , if you send someone a crew battle and they dont accept or decline ,you will lose the 25k it took to send the challenge. so setup the crew battle before you send or you will just hurt yourself and your crew.
Experience
whoever jumps in the first couple of days is gonna have the most exp , but they get the most exp from racing the guys with the lowest nw and lowest lvl. so you can either jump in nw the first couple of days and do it that way , or just spam the top 3 guys and build exp that way. stay at lvl 1 until you are ready to lvl. lvl 20+ is best for HIn , thats about 350k exp , so it wont take much. more than that will only help in crew avg skill and racing people.
Additional advice
Remember , this is just a game. enjoy playing it. Practice , tune your skills and become the best. having enemies is fun , God knows i made alot during my 8 months on mc , but whats more important is friends and your crew. i have run with the best there will ever be in this game and the best guys ive ever had the plesure of knowing. if you get HId , dont send a PM sounding like an idiot , "[censored] you bitch , im going to [censored] you up". simply send "im sorry that you felt you had to come over to my house w/o me inivting you. i enjoyed your visit and i will have to return the favor very soon". be nice , act confident even if you arent. earn respect , dont make people hate you , make people respect you.
*******MOST IMPORTANT*********
The people you talk to and run with can make you or break you. Listen to what vet's and your friends have to say. Communicate with one another. Don't be a loner , you will never win that way.
The people who taught me so much and who deserve respect
Dan Danger
Pussy
Jdoggy
Greenteg
Smokincivic
Slammedfire
SSVegito
Rakimdream
Realm
Side Note
Danj has taught me almost everything i know in this game. if it werent for him , i would never of been able to learn everything that is in this Bible. I owe you everything Danj. Thanks for everything man.
Closing
it has been a blast playing with all of you and i will miss playing with the best players in the game. this tutorial is free b/c i want to pass everything i have learned onto all of you. i am passing the torch onto all of you. use this guide well and good luck to all of you. i will miss this game and all of you.
Now, these are just some random numbers that have worked for me in the past:
340/445 at home, 5.5 times ur NW
152/150-Recruiting, 4 times ur NW
Try-108/269
Most of that information is outdated and useless. That bible was written over a year ago, so I don't see how it is relevant. All of those HI numbers are hilarious, no one uses 400 credits for a HI anymore. That is an old school bible, and is only useful if you are TRULY a new player and you are in need of basic advice, ie. simple cruising and working strategies.
Grossnwill Wrote:Most of that information is outdated and useless. That bible was written over a year ago, so I don't see how it is relevant. All of those HI numbers are hilarious, no one uses 400 credits for a HI anymore. That is an old school bible, and is only useful if you are TRULY a new player and you are in need of basic advice, ie. simple cruising and working strategies.
Thats exactly why Rick created this thread..
All I need is One Mic.
it is outdated , i noted that in my post. i posted THOSE #s b/c those are the ones i use the first day to jump from $7k to $6.8mil. so no , they are not useless , you can just use alot lower #s. i would suggest using a bigger # when you are starting out and want to jump quickly as i do.
and there is basic cruising and working info in there that you can still use. thanks Wink
exactly the point. The new players need somewhere to start and this helps. Some of the info is outdated, so what? If it is that useless instead of spending your time making derogatory posts which seems your specialty, write a new one.
I obviously can't write a new bible myself, I do not have enough MC skill to do that.
I do remember reading Teet's bible along time ago and it really was very useful, so thanks for writing it Teet.
By the way Calder, I'm sorry- I didn't realize that you posted Teet's bible just for the basic concepts (working and cruising)
Smile it's all good. I don't have the knowledge either or I would do it myself.
I love hitting 10000x your NW first try first day 8)
When I Fall Asleep You're All That I See, I Wish I Could Be All That You Mean To Me, My Angel Without Wings Smile
Rakim I love you <3
hahahaha i had that bible how long ago too
  starting cash svtfox91 4 3,215 08-28-2016, 03:21 PM
Last Post: rebekahdo11
  Hey Teet! Tokkiez 8 2,570 11-06-2013, 08:00 PM
Last Post: SSVegito
  Congrats to Teet guess_who 32 7,474 04-21-2012, 11:10 PM
Last Post: Tokkiez
  I wonder what the chances of it starting on time are? Dyna 26 6,344 09-14-2009, 12:38 PM
Last Post: Tokkiez
  Starting off on the right foot... lenko 27 8,934 05-31-2008, 11:40 AM
Last Post: Hitman666
  Starting Out? ezeedee 54 12,593 01-09-2006, 05:14 PM
Last Post: teet
  Look Now its Starting!!! RippingRider 27 6,057 10-04-2005, 12:40 PM
Last Post: InitialD
  When is MC starting again? Renzo 29 6,712 10-01-2005, 03:57 PM
Last Post: monteman
  thanx teet... LuDe 26 5,628 09-27-2005, 03:22 PM
Last Post: LuDe
  this what i look like after starting 2 days ago! HOMIEPA 17 4,820 06-06-2005, 01:58 PM
Last Post: LuDe
1 Guest(s)
