random test n' tune times and negative cash
The test n' tune times are all over the board when I'm trying to tune. I can run the same settings over and over again and get full second differences in the time. This isn't how it was prior to the beta.
also, I logged in today and I have $-75,000 in my cash field. My net worth has dropped way down, and there's no history of getting HI'ed. What's going on?
What is your login name?
What was your NW and cash prior to this happening? So you had X networth and Y cash, logged out, then logged in later and you had -$75,000?
My login is djxero
My previous net worth was over 200k, with a little over 125k in the cash field, and now it shows -75.
So I logged this morning, and I had $15,000 in cash. A far cry from what I originally had before I went negative. I worked my way up to about $500,000 in cash. I just raced 4 or 5 times (everyone is out of fuel) and now all of the sudden I have $-924,957.
Xero Wrote:So I logged this morning, and I had $15,000 in cash. A far cry from what I originally had before I went negative. I worked my way up to about $500,000 in cash. I just raced 4 or 5 times (everyone is out of fuel) and now all of the sudden I have $-924,957.
You went negative cash? or networth? And it happened right after you raced someone???
Negative cash, I assume my me went with it. I just can't understand how it would have dropped so fast and in the negative if I was racing. The I don't think any of them were actual wins or losses.
Xero Wrote:Negative cash, I assume my me went with it. I just can't understand how it would have dropped so fast and in the negative if I was racing. The I don't think any of them were actual wins or losses.
I'm confused.. so you were positive cash, raced someone, then had negative cash?
That's right. I raced someone and then I looked up and was in the negative.
there is risks involved in racing. if u raced some1 and lost this could be why
**edit**
if this is the case this should be fixed to where u cant race ppl that u cant cover the risk of the race
LarryG Wrote:there is risks involved in racing. if u raced some1 and lost this could be why
**edit**
Correct... I believe this is what was happening. Fixed.
  Dyno Tune/TNT cash bug Xero 1 1,479 03-08-2015, 08:20 PM
Last Post: C-speed
  Test n Tune Kiro 2 1,600 02-11-2015, 09:11 PM
Last Post: Kiro
Lightbulb cash bug racerr 1 1,396 02-09-2015, 09:37 PM
Last Post: C-speed
  Most Cash Earned In A Home Invasion CamCressi 8 4,303 08-07-2013, 04:06 PM
Last Post: CamCressi
  This negative bug nw bug. I figured it out and what theyre doing. Tokkiez 3 1,487 03-26-2013, 07:31 PM
Last Post: Tokkiez
  HI resulting in negative NW bug Admin 4 2,198 03-26-2013, 07:49 AM
Last Post: NoToRiOuS_ThUgS
  You do not have enough cash to cover the risk. teet 1 1,379 09-10-2011, 06:52 PM
Last Post: Tokkiez
  negative import models? LarryG 2 1,792 07-12-2011, 10:55 PM
Last Post: v2pointOH
  cruising work and negative Teal_Eg6 0 1,141 07-05-2011, 06:31 PM
Last Post: Teal_Eg6
  negative models Tokkiez 0 1,130 07-03-2011, 07:05 PM
Last Post: Tokkiez
