Computer Trouble
Hello, you either have JavaScript turned off or an old version of Macromedia's Flash Player, click here to get the latest flash player.
can any help me i have the lastes flash player
but i dont know how to turn on my javascript
go to start menu...control panel...java then under advanced go to tag support and check the boxes u want java to run in such as your internet explorer. If that dont work go to java consol and make sure its not checked under do not start console.
Connor: Now Roc... are you sure that you're obee-kaybee?
Yeah if he has Suns Java installed =/
Go to tools in IE > Internet Options > Advanced
Scroll down till you find Microsoft VM
Make sure it is enabled, if it isn't you will need to reboot after you enable it.
He said javascript, not java - those are two different things. You turn javascript on in your browser options section (exactly where depends on the browser). For IE you'd go to internet options | security | custom level
and set "Active scripting" to "Enable"
  RE: My Computer :( Xaero 4 1,774 08-17-2008, 10:12 AM
Last Post: teet
  Picture of trashed computer area danny 2 1,472 04-04-2006, 12:06 PM
Last Post: 200mphblur
