tnt'ing
got the level 1 porsche and did some light tuning (tire, turbo, testpipe, FI ECU) and went to TNT, but couldn't because it said I entered an invalid number. got this at the screen without any fields to fill (the first one you see when you click "test n' tune"
had 110 creds and like 500 dollars...
01101111 01101101 01100111 01111010 00100000 01110100 01100101 01101000 00100000 01100010 01110101 01110100 01110100 01110011 01100101 01100011 01101011 01110011 00100001
this has been covered, yes a bug but here is the fix
1. get in a car that does tnt
2. run one tnt so you get to the screen with the numbers in it
3. get in the bugged car
4. use the browser back button to return to the tnt screen with the numbers
5. tnt the car.
you may have to but a pos if you don't have a second car this early, but it does work
thx, haven't played in a while, so im not up to speed...
np man, enjoy Smile
Rick i have the same problem...i tried what you said to do but it still don't work
Restricted
You have to change the number once ya go back change the one number that is bugged to 0 and you should be all fixed up...i think the bugged number should be the last one!
No Whining please!
i tried it was ok 1 so i changed it to 0 but it brought it went back to invalid value...but thanks any way
Restricted
It works everytime, double check the other numbers make sure they are ALL in range, worst case scenario set them to 36, 36, 8, 8, 0 and start from there. I have never seen this not work
Two most common causes for it to fail:
1. you went back to the initial tnt run, go back only far enough to enter numbers
2. you still have an out of range number (this has never happened to me =/ it keeps the numbers from the car you just ran so I can't see how it could lol)
Is this bug ever going to be fixed? Last time this happened trying to tnt a Trueno I bought a civic to get into tnt - this time the civic doesn't even work.
Edit:
OK, I tried entering the values as a URL and it worked! i think it was damper_R=0 that was the problem, i changed it to 1 and camber to 0
example:
http://midnitechallenge.com/proc_testntu...1&camber=0
grr ive got this bug. I tried the fix as well as I could understand. I bought another car and attempted to test n tune it, same problem. If there is a way to get around this please let me know...and if one is already listed and im just not getting it please spell it out for me.
1 Guest(s)
