	Threads: 52
		So i got a new toy ...
its set up for dritfing ..
RB20DET str8 six with a 25T turbo ..
deep dish 5 spoke mags on streched tires.
3" exhst
turbosmart stage 2 vport blow off valve
38" external
lowerd
frount mount
etc.
wanna make it go quicker ..
atm boosting 10 pounds doing around the 13.2 mark on a 1/4 mile
wanna pump anther maybe 2k into the engin.
anyone know of anything i can do ..i got some ides ...re-map comp..etc.
Black__Metal
	Threads: 5
		:nx:break out the bottle!!  :nx:
	Threads: 52
		yea i was thinking about a nos set up in it ...
it seems to be getting a bit bigger over here ...
i might look into that.
Black__Metal
	Threads: 17
		Sell that one and buy 3 cars with a real motor.  An older Mustang, an older Camaro, and an old Demon.  That way all of them are faster and when you finally break one you have 2 more waiting.
EAT A PUNCH JUST TO MAKE YOU TAP
BJJ-Purple Belt
Resident Engineer, Geologist, Genius
	Threads: 29
		If you want to keep it set up for drift do not get nitrous. I would say build the motor with a good forged piston and rod and try to get a different turbo. That would make alot more sense because if I am right you can not use nitrous when in a drift event...
	Threads: 52
		Jered - lmfao its not worth the value of 3 cars
Yea ive sorta died off the drift events atm tho cartman.most of the engin has been rebuilt with good stuff. just wanna get a tad more power outa her or up the boost.maybe a bigger turbo and bigger spring in wastegate is in order.
Black__Metal
	Threads: 5
		04-17-2008, 01:03 PM
(This post was last modified: 04-17-2008, 01:08 PM by Nick318.)
		a 30-50 shot of nitrous would really wake the car up, I think we can all agree that turbos love nitrous. haha then again nitrous will wake up every car...
Edit: Only 10psi of bost??? I'm not the greatest on turbo mapping, but shouldn't you be able to get atleast get 15psi out of that turbo?
	Threads: 29
		I would say different turbo if it has a built motor and then double the boost and you should be happy
	Threads: 52
		yea its got a lil over 15 pound in it,
just running it low so i dont do anything stupid 2 the engin.
plus im only running a 10 pound spring in wastegate ..ill up that to a 13 or 15 pound spring now...
just not sure what turbo ... maybe a t4/t5 ? or a garret5 or something ??
nos might be a tad fun...just for shits and giggles...
anyone know a good computer/ecu upgrade for it ...
or should i just get it re-mapd ??
Black__Metal
	Threads: 5
		if you have 2k to blow, build the motor. 15lbs of boost on a built 6cyl would get that car screaming down the track.
