Can't dyno. - Printable Version +- Midnite Challenge Forums (http://www.midnitechallenge.com/forums) +-- Forum: Support (http://www.midnitechallenge.com/forums/forumdisplay.php?fid=4) +--- Forum: Bugs and Support (http://www.midnitechallenge.com/forums/forumdisplay.php?fid=12) +--- Thread: Can't dyno. (/showthread.php?tid=87) |
Can't dyno. - TheOutlaw - 04-15-2005 What is the problem?: Can't dyno Login name?: EdwardRoper What page does the error occur on?: http://www.midnitechallenge.com/dyno.php?type= What did this affect on your account?: Speed and power Any other information you thought was worth adding?: I am doing this for a friend because he can't win race's if his car is at a P/R of 200. Thank you for your time. Please put the origanal thingy back up so we can do these thing properly.lol. Can't dyno. - monteman - 04-15-2005 You didn't explain alot...be more specific. What error are you getting? Can't dyno. - PoTh - 04-30-2005 Bump im having this same problem. i get this You cannot dyno tune at this time as you have a race pending. Can't dyno. - Skatanic - 05-19-2005 yea i keep getting that too.it says i have a race pending and i cant dyno tune but i dont have a race pending Can't dyno. - wannago - 05-23-2005 i used to always get that message everytime but i dont anymore. Can't dyno. - Allsopp - 05-24-2005 Quote:yea i keep getting that too.it says i have a race pending and i cant dyno tune but i dont have a race pending Did u decline a race if so log out an bak in an then Dyno ![]() Can't dyno. - admedlin - 05-24-2005 actually i had it too and i think it happens based on the amount of power you are trying to dyno. I had about 1100 power and was dynoing down to 900 and it said that. what i usually do when i am setting up my car is buy all the parts and upgrades before i buy the ECU. Once i buy everything, i put on the ECU, go to dyno and move all the numbers to 27. Then i take off the ECU and reinstall it. Go back to dyno and make the line. It'll say 100% at a very low number. By doing this, you can dyno down using about 75 points instead of 40, meaning you can lower your power a lot more than without using this method. Try this when setting up your car and there is a certain point where you can't change the numbers any lower. This point is different depending on the skill level and power rating of the car. I've found that at lower skill levels and power, you can only change your dyno by maybe 10-15 points, but you can start changing it more drastically later with more power and higher skill level. I've only been playing for 7 months so I'm still a noob, but i think this should help anyone having dyno problems. Can't dyno. - s4rx7 - 08-10-2005 i installed a turbo kit on a stock trueno and it says my HP is 80!! so i go to tune it and i get the same message Can't dyno. - david_mullen18 - 08-11-2005 3 MONTH OLD POST AGAIN AHHHHHH!!! Can't dyno. - mecca_boy - 08-11-2005 Stop whroing thread like this enless u can help them then say stuff but since you cna't shut up this is your first warning |
