Warning [2] Undefined variable $awaitingusers - Line: 67 - File: global.php(816) : eval()'d code PHP 8.2.32 (Linux)
Warning [2] Undefined array key "style" - Line: 874 - File: global.php PHP 8.2.32 (Linux)
Warning [2] Undefined property: MyLanguage::$lang_select_default - Line: 4984 - File: inc/functions.php PHP 8.2.32 (Linux)
Warning [2] Undefined array key "additionalgroups" - Line: 6987 - File: inc/functions.php PHP 8.2.32 (Linux)
Warning [2] Undefined array key 1 - Line: 1399 - File: inc/functions.php PHP 8.2.32 (Linux)
Warning [2] Undefined array key "showimages" - Line: 167 - File: printthread.php PHP 8.2.32 (Linux)
Warning [2] Undefined array key "showvideos" - Line: 172 - File: printthread.php PHP 8.2.32 (Linux)
Warning [2] Undefined array key "action" - Line: 140 - File: inc/plugins/automedia/automedia_functions.php PHP 8.2.32 (Linux)
Warning [2] preg_match(): Compilation failed: invalid range in character class at offset 49 - Line: 28 - File: inc/plugins/automedia/mediasites/twitter.php PHP 8.2.32 (Linux)
Warning [2] Undefined array key "action" - Line: 340 - File: inc/plugins/automedia/automedia_functions.php PHP 8.2.32 (Linux)
Warning [2] Trying to access array offset on value of type null - Line: 1182 - File: inc/functions.php PHP 8.2.32 (Linux)
Warning [2] Trying to access array offset on value of type null - Line: 1188 - File: inc/functions.php PHP 8.2.32 (Linux)
Warning [2] Undefined array key 4031 - Line: 1182 - File: inc/functions.php PHP 8.2.32 (Linux)
Warning [2] Undefined array key 4031 - Line: 1188 - File: inc/functions.php PHP 8.2.32 (Linux)
Test n Tune - Printable Version
+--- Thread: Test n Tune (/showthread.php?tid=6414)
Test n Tune - Kiro - 02-10-2015
Is anyone else finding it incredibly difficult to TNT a car as what you use to get the numbers down to TNT it change with each time causing it to jump up so high. At this rate to TNT a car it seems like it would take tons of credits, I don't remember it being like this?
Any feedback on this would be helpful.
RE: Test n Tune - C-speed - 02-11-2015
Can you give an example of what you're talking about (with numbers)?
RE: Test n Tune - Kiro - 02-11-2015
The number you usually use to tune it to get as low as possible changes so fast, it can be like 1.02 or w/e, then you move 1 of the numbers down and it jumps to 1.3 and its not because lowering the number made it worse, it seems its because the numbers are so sporadic that during a TNT you will run 7.5 then a 7.8, this is not how I remember it being for TNT's they were consistent so you could tune it from what I remember.
