The following warnings occurred: | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Leveling - Printable Version +- Midnite Challenge Forums (http://www.midnitechallenge.com/forums) +-- Forum: Miscellaneous (http://www.midnitechallenge.com/forums/forumdisplay.php?fid=7) +--- Forum: Game Idea's and Suggestions (http://www.midnitechallenge.com/forums/forumdisplay.php?fid=20) +--- Thread: Leveling (/showthread.php?tid=6198) |
Leveling - JAClark10 - 01-21-2012 You should have to level to a certain level before you can HI and Boost.. And the level should be shorten just a little bit. Just a suggestion... ![]() Leveling - YmCmB - 01-21-2012 JAClark10 Wrote:You should have to level to a certain level before you can HI and Boost.. And the level should be shorten just a little bit. Just a suggestion... i agree the its hard to lvl now days i think they should shorten the exp or make it to were you earn more exp a race Leveling - DoomsDay - 01-21-2012 I also think that if you steal a higher lvl car you shouldnt be able to get in it until you are at that lvl or even use the upgrades until you reach the lvl. it would make people spend more if they had to get to lvl 5 before they could HI Leveling - YmCmB - 01-21-2012 DoomsDay Wrote:I also think that if you steal a higher lvl car you shouldnt be able to get in it until you are at that lvl or even use the upgrades until you reach the lvl. it would make people spend more if they had to get to lvl 5 before they could HI agreed i believe if you still a higher lvl car all the parts on it should be taken off till they reach the level make it more challenging Leveling - NoToRiOuS_ThUgS - 01-21-2012 all good suggestion maybe once more changes happen ill come back and try it again but til then im not playing |
