The following warnings occurred: | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
DYNO - Printable Version +- Midnite Challenge Forums (http://www.midnitechallenge.com/forums) +-- Forum: Support (http://www.midnitechallenge.com/forums/forumdisplay.php?fid=4) +--- Forum: Bugs and Support (http://www.midnitechallenge.com/forums/forumdisplay.php?fid=12) +--- Thread: DYNO (/showthread.php?tid=616) |
DYNO - lithium - 06-29-2005 Whenever i ry to dyno tune i get this message i signedoff and signed back on. i took everything off my car.and it still does it You cannot dyno tune at this time as you have a race pending. DYNO - matrixcommodore - 06-29-2005 i get it aswell DYNO - admedlin - 07-26-2005 are you trying to change a lot of power or just to set it up? b/c if you try to change the power by too much thru dyno, that message will pop up. you just have to play with it and find out how much power is being changed DYNO - eXpLoSiVe - 07-31-2005 Quote:are you trying to change a lot of power or just to set it up? b/c if you try to change the power by too much thru dyno, that message will pop up. you just have to play with it and find out how much power is being changed I'm getting this error as well, and I'm not making drastic changes to my figures. I even tried changing it by 2 and it still gave me the error. Tried logging out and back in as well as waiting for all the pending/accepted races to happen for a few rounds to see if that would help, but no luck. Quote:http://www.midnitechallenge.com/dyno.php?type=&error=5 DYNO - TheSkater - 08-04-2005 Yeah ive been getting that message for a few days, and im not gonna raise my NW without using the dyno first-so im pretty much stuck |
