The following warnings occurred: | |||||||||||||||||||||
READ FIRST: New Vehicle Suggestions - Printable Version +- Midnite Challenge Forums (http://www.midnitechallenge.com/forums) +-- Forum: Miscellaneous (http://www.midnitechallenge.com/forums/forumdisplay.php?fid=7) +--- Forum: New Vehicles and Add-on's (http://www.midnitechallenge.com/forums/forumdisplay.php?fid=22) +--- Thread: READ FIRST: New Vehicle Suggestions (/showthread.php?tid=5766) |
READ FIRST: New Vehicle Suggestions - Admin - 03-17-2010 If there is a vehicle you'd like to see added to Midnite Challenge, please make a new post in the following format: - Year, make, model - MSRP - Engine layout (FF, FR, RR, MR, FA, etc) - Engine size (liters) - Number of cylinders - Naturally Aspirated, Turbocharged or Supercharged - Engine Code - Stock Horsepower and Torque - Factory intercooled? - Factory port and polish? - Vehicle weight (lbs) - Available colors from the manufacturer - Real life possible engine swaps - You MUST include TWO photos that follow the same look as the current cars in the game. One side view and one 3/4 view, ie: Additional info required if there are possible engine swaps: - Engine codes for each swap - Stock Power/Torque - Naturally Aspirated, Turbocharged or Supercharged - Typical cost for the swap |
