Warning [2] Undefined variable $awaitingusers - Line: 67 - File: global.php(816) : eval()'d code PHP 8.2.33 (Linux)
Warning [2] Undefined array key "style" - Line: 874 - File: global.php PHP 8.2.33 (Linux)
Warning [2] Undefined property: MyLanguage::$lang_select_default - Line: 4984 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key "additionalgroups" - Line: 6987 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 1 - Line: 1399 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key "showimages" - Line: 167 - File: printthread.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key "showvideos" - Line: 172 - File: printthread.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key "action" - Line: 140 - File: inc/plugins/automedia/automedia_functions.php PHP 8.2.33 (Linux)
Warning [2] preg_match(): Compilation failed: invalid range in character class at offset 49 - Line: 28 - File: inc/plugins/automedia/mediasites/twitter.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key "action" - Line: 340 - File: inc/plugins/automedia/automedia_functions.php PHP 8.2.33 (Linux)
Warning [2] Trying to access array offset on value of type null - Line: 1182 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Trying to access array offset on value of type null - Line: 1188 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 1666 - Line: 1182 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 1666 - Line: 1188 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 154 - Line: 1182 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 154 - Line: 1188 - File: inc/functions.php PHP 8.2.33 (Linux)
Possible change in experience - Printable Version
+-- Forum: Miscellaneous (http://www.midnitechallenge.com/forums/forumdisplay.php?fid=7)
+--- Forum: Game Idea's and Suggestions (http://www.midnitechallenge.com/forums/forumdisplay.php?fid=20)
+--- Thread: Possible change in experience (/showthread.php?tid=4171)
Possible change in experience - beluga - 01-29-2008
Here is my idea-currently to get experience, you race people with drastically different nw. Usually, this means that one person is wayyyy faster than the other. In reality, if you get crushed in a competition, you don't learn that much. Or if you are the one doing the crushing (beating your opponent by a lot), you learn less. So my suggestion (I don't know if this has been suggested before), is to do it by number of races/level. You learn by doing this repeatedly, so more races=more experience. At the beginning of the game, you wait for someone to get high nw, you race them once, and you jump like 8 levels. You follow this pattern until you get to level 20 or so, and then you race low nw people. The current system promotes the creation of multis so you always have someone with low nw to race. Is there anyone out there who really thinks that people would have an account with less than $10,000 nw that is not a multi? So this change would discourage the creation of multis, and also promote racing among top levels to test out how fast their cars were against their competitors, rather than racing low nw people solely for the sake of experience. I know that this has a problem with autoplay, but those races could be worth .1 or something of a real race.
Possible change in experience - TheJMan - 01-29-2008
ohhh changing the exp again will be hard to come by ..
ok lets go thrw this point by point ..
In real life which the game is not ... would you not learn greatly from someone that was much better then you .... dosnt that go for anything ?? someone that is better than you in something is the best teacher because they have got it down and you learn.
if it was the other way around ..the guy doing the crushing would not learn alot at all
this i belive is what the exp thing is based around so far.
im not a muiltie and ive been about 20k all round...
some people jump on work once and then sit on AP all round to help mates up the top etc.
and most of the top level guys know what level eachothers are and know how much per race they are getting and everything.There is alot of info behind what everyone sees.
at the moment the exp is bassed on races and levels.
Possible change in experience - modogg85 - 01-30-2008
The most EXP you can receive, and a lot of the top players follow this, is you got to get a level partner that is the same level as you are. One person spends the credits to jump up in NW, while the other one stays a relatively low NW. Mean the most EXP for a level 38 guy would be to have 2 level 38 guys race eachother. 1 of them be at lets say 10 billion, while the other one is at 100 million or something like that.
