Official 2000 TVR Speed 12 thread - Printable Version
+-- Forum: Miscellaneous (http://www.midnitechallenge.com/forums/forumdisplay.php?fid=7)
+--- Forum: New Vehicles and Add-on's (http://www.midnitechallenge.com/forums/forumdisplay.php?fid=22)
+--- Thread: Official 2000 TVR Speed 12 thread (/showthread.php?tid=4161)
Official 2000 TVR Speed 12 thread - Xaero - 01-24-2008
In Detail
price $245 000 USD
engine V12 w/High Molybdenum EN14T steel block, EN40B nitrided steel crankshaft and EN24B conrods, Dry Sump Lubrication
valvetrain 4 Valves per Cyl
fuel feed Fuel Injection
displacement 7731 cc / 471.7 cu in
compression 12.5:1
power 656.2 kw / 880 bhp @ 7250 rpm
hp per litre 113.84 bhp per litre
bhp/weight 902.56 bhp per weight
torque 881.3 nm / 650.0 ft lbs @ 5750 rpm
drive wheels RWD w/Harrop LSD
body / frame Carbon Fibre Body over Aluminum Honeycomb Tub w/Tubular T45 Steel Rollcage & Subframes
front brakes Vented Discs
f brake size 378 mm / 14.9 in
rear brakes Vented Discs
r brake size 273 mm / 10.7 in
front wheels F 45.7 x 27.9 cm / 18 x 11 in
rear wheels R 45.7 x 33.0 cm / 18 x 13 in
front tire size 245/35ZR18 Goodyear F1 Fiorano
rear tire size 335/30ZR18 Goodyear F1 Fiorano
f suspension Double Wishbones w/Coil Shocks over Gas Dampers, Anti-Roll Bar
r suspension Double Wishbones w/Coil Shocks over Gas Dampers, Anti-Roll Bar
weight 975 kg / 2150 lbs
wheelbase 2642 mm / 104.0 in
length 4300 mm / 169.3 in
width 1960 mm / 77.2 in
height 1100 mm / 43.3 in
transmission 6-Speed Hollinger Sequential
top speed 386.2 kph / 240 mph
0 - 60 mph est 3.5 seconds
information gathered from http://www.supercars.net
Can we add what level we think that car can be purchased at?
any more contributions, we still need colors and parts... thanks. Smile
