Referal Bug - Printable Version
+--- Thread: Referal Bug (/showthread.php?tid=4007)
Referal Bug - Lil-Luceifer - 12-07-2007
A few problems have arisen after the previous changes.
The Refering thing is good but it should process the request 1st.
Eg. when sending a message if you click send and you get a verification thing it will refer to send_process.php or what ever it is instead of messages& error= 2 or what ever it says which means its stent and basicall this means what ever you write dissapears and you have to re write it. VERY ANNOYING happened o me a few times. Also same thing when HIing but worse. You suss out your timeing and have your number in and you click invade and it wants to verify you but it doesn't actually process the HI so you have to go wait for timing and such again and also. It refers to Homeinvade.php instead of homeinvade.php&opponentID=XXXX which means you are trying to HI nothing at all so it is a waste of credits. I have done this quite a bit and lost a few thousand credits. Re-Imbursement would be good if possible bug i understand if it isn't.
Thanks
