The following warnings occurred: | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
level 20 porsche 911 - Printable Version +- Midnite Challenge Forums (http://www.midnitechallenge.com/forums) +-- Forum: Midnite Challenge (http://www.midnitechallenge.com/forums/forumdisplay.php?fid=3) +--- Forum: Cars, Mods and Tuning (http://www.midnitechallenge.com/forums/forumdisplay.php?fid=10) +--- Thread: level 20 porsche 911 (/showthread.php?tid=3838) |
level 20 porsche 911 - hanabada - 10-21-2007 how the hell you get down to 9.759. no matter how much i tune, i can only get to 9.80 fastest.. grr :mad: does having stock tires make it run faster? or the dampers and suspension? level 20 porsche 911 - D1STURB3D - 10-21-2007 the time you want is 9.758, try tnt again and make sure you have the highest handeling rating of 735 level 20 porsche 911 - hanabada - 10-22-2007 i got handling of 737 but i still run slow. man! level 20 porsche 911 - krazyman06 - 10-22-2007 then what u have to do is figure out the best possible power rating as well ![]() the easiest way to do that is take a stock 911 and add 1 part at a time then dyno'ing and figuring out which part gives u the greatest incline in horsepower per set of parts and then when u get done doing all those install ur nitrous and the correct parts and ur good to go level 20 porsche 911 - hanabada - 10-23-2007 im still stumped on how you got down to 9.758... boo.. level 20 porsche 911 - modogg85 - 10-24-2007 it takes time. You got to test out the different parts to find the right part. THen you need to add all the upgrades, and with the proper TnT you will achieve that. I dont think that its worth the trouble unless you are going for IDE level 20 porsche 911 - bscar - 10-24-2007 I wouldn't think you'd need ALL the upgrades, but maybe the boost/nitro stages would help, I dunno. level 20 porsche 911 - og-invisible - 11-17-2007 all i got to say is i got porsche 911 pr:180 hr: 737 tnt: 9.761 ;[ spam a shit load til i finally get 9.758 what i think is its not really about the pr its more of the hr with tnt then your luck on spamming the ww3 all in all some cars depends on pr for better timing in ww3 and some dont level 20 porsche 911 - bscar - 11-17-2007 note that it's the RE050 tires on the list ![]() |
