Warning [2] Undefined variable $awaitingusers - Line: 67 - File: global.php(816) : eval()'d code PHP 8.2.28 (Linux)
Warning [2] Undefined array key "style" - Line: 874 - File: global.php PHP 8.2.28 (Linux)
Warning [2] Undefined property: MyLanguage::$lang_select_default - Line: 4984 - File: inc/functions.php PHP 8.2.28 (Linux)
Warning [2] Undefined array key "additionalgroups" - Line: 6987 - File: inc/functions.php PHP 8.2.28 (Linux)
Warning [2] Undefined array key 1 - Line: 1399 - File: inc/functions.php PHP 8.2.28 (Linux)
Warning [2] Undefined array key "showimages" - Line: 167 - File: printthread.php PHP 8.2.28 (Linux)
Warning [2] Undefined array key "showvideos" - Line: 172 - File: printthread.php PHP 8.2.28 (Linux)
Warning [2] Undefined array key "action" - Line: 140 - File: inc/plugins/automedia/automedia_functions.php PHP 8.2.28 (Linux)
Warning [2] preg_match(): Compilation failed: invalid range in character class at offset 49 - Line: 28 - File: inc/plugins/automedia/mediasites/twitter.php PHP 8.2.28 (Linux)
Warning [2] Undefined array key "action" - Line: 340 - File: inc/plugins/automedia/automedia_functions.php PHP 8.2.28 (Linux)
Warning [2] Trying to access array offset on value of type null - Line: 1182 - File: inc/functions.php PHP 8.2.28 (Linux)
Warning [2] Trying to access array offset on value of type null - Line: 1188 - File: inc/functions.php PHP 8.2.28 (Linux)
Warning [2] Undefined array key 563 - Line: 1182 - File: inc/functions.php PHP 8.2.28 (Linux)
Warning [2] Undefined array key 563 - Line: 1188 - File: inc/functions.php PHP 8.2.28 (Linux)
Warning [2] Undefined array key 653 - Line: 1182 - File: inc/functions.php PHP 8.2.28 (Linux)
Warning [2] Undefined array key 653 - Line: 1188 - File: inc/functions.php PHP 8.2.28 (Linux)
Warning [2] Undefined array key 1186 - Line: 1182 - File: inc/functions.php PHP 8.2.28 (Linux)
Warning [2] Undefined array key 1186 - Line: 1188 - File: inc/functions.php PHP 8.2.28 (Linux)
Warning [2] Undefined array key 122 - Line: 1182 - File: inc/functions.php PHP 8.2.28 (Linux)
Warning [2] Undefined array key 122 - Line: 1188 - File: inc/functions.php PHP 8.2.28 (Linux)
Warning [2] Undefined array key 841 - Line: 1182 - File: inc/functions.php PHP 8.2.28 (Linux)
Warning [2] Undefined array key 841 - Line: 1188 - File: inc/functions.php PHP 8.2.28 (Linux)
Warning [2] Undefined array key 217 - Line: 1182 - File: inc/functions.php PHP 8.2.28 (Linux)
Warning [2] Undefined array key 217 - Line: 1188 - File: inc/functions.php PHP 8.2.28 (Linux)
Crew battle etiquette? - Printable Version
+--- Forum: Crews - Recruiting and Strategies (http://www.midnitechallenge.com/forums/forumdisplay.php?fid=9)
+--- Thread: Crew battle etiquette? (/showthread.php?tid=2092)
Crew battle etiquette? - calder12 - 12-07-2005
Being still kinda new I want to get everyones opinion here. Is it better to send a message asking if it is ok to challenge another crew or do you just challenge and accept it if they decline?
Crew battle etiquette? - R_Y_A_N - 12-07-2005
This is the way Blackrain thinks, if the crew thinks they are good enough they will accept, if they know they are not the will decline, and I back him up on this
Can you all give your thoughts on why too? thanks Smile
Crew battle etiquette? - Black_rain13 - 12-07-2005
Actually, I think it is fucked up when you challenge a crew and instead of declining cause they can't beat you, they just delete the challenge and you lose that 25K forever. I won't send a challenge to a crew leader unless they tell me it is ok... after that, I don't ask for each challenge.. usually you ask once and they tell you to just hit them anytime you are ready, or they will tell you, "sure, I'm down for one or two"...
Most crews when they start out can't afford to lose 25K in CBR especially to 3 or 4 different crews...
As such, I always suggest courtesy and pre-warning first before sending blind challenges.
Crew battle etiquette? - Ruf - 12-07-2005
A
Crew battle etiquette? - slickNsxy - 12-08-2005
in the grand scheme....25Gs is nothing to a strong crew so if someone delets your challenge it doesnt hurt too much
but i think its better to ask first. my reason behind it is so you know exactly when your races are going in, so you can plan on when to get a new car and tnt and all that other crew leader stuff you need to do.
Crew battle etiquette? - PIMP_4_LIFE - 12-09-2005
id have to say just send the invite becuase they might not on at the same times you are as come on theres people from all around the world so it could take days to get a reply if you just send the invite its way easier and if they do not want to race they just decline it. Its easy as..
Crew battle etiquette? - Black__Metal - 12-11-2005
jst send away ...who cares if u dont accept atlst u tryed
