Power rating at 86%? - Printable Version +- Midnite Challenge Forums (http://www.midnitechallenge.com/forums) +-- Forum: Midnite Challenge (http://www.midnitechallenge.com/forums/forumdisplay.php?fid=3) +--- Forum: General Game Discussion (http://www.midnitechallenge.com/forums/forumdisplay.php?fid=8) +--- Thread: Power rating at 86%? (/showthread.php?tid=1980) Pages:
1
2
Power rating at 86%? - Sp4rt4n - 11-27-2005 How can i get my power rating up from 86%? and why does it go down? Power rating at 86%? - o_O_Tread_O_o - 11-27-2005 easiest way is to install a throttle bottie Power rating at 86%? - Black__Metal - 11-27-2005 dyno tune ... Power rating at 86%? - GODthurisnoother - 11-27-2005 dyno tune all numbers to 70 lol most of the time that gets you close enough lol Power rating at 86%? - o_O_Tread_O_o - 11-27-2005 dyno to 12.6 if it is FI and 13.6 if it is N/A Power rating at 86%? - Sp4rt4n - 11-27-2005 liltreadburn Wrote:dyno to 12.6 if it is FI what are you talking about? 12.6? which link is that under? and i put everything to 70 and it went from 86-89 :/ Power rating at 86%? - GODthurisnoother - 11-27-2005 your dyno should look like this if done rite Power rating at 86%? - Sp4rt4n - 11-27-2005 hmm... mines at about 13.9, how do i lower it? Power rating at 86%? - GODthurisnoother - 11-27-2005 play with the numbers lol the higher the number the lower the line will be on the graph so say for 1000 rpm your number is 65 to bring the line lower on the graph you need 66 or higher i hope you can make seence of that lol Power rating at 86%? - Sp4rt4n - 11-27-2005 ok, so the higher the number, the lower the line? |
