Changing display name (racename) - Printable Version +- Midnite Challenge Forums (http://www.midnitechallenge.com/forums) +-- Forum: Support (http://www.midnitechallenge.com/forums/forumdisplay.php?fid=4) +--- Forum: Bugs and Support (http://www.midnitechallenge.com/forums/forumdisplay.php?fid=12) +--- Thread: Changing display name (racename) (/showthread.php?tid=1906) |
Changing display name (racename) - vtec_666 - 11-17-2005 When I try to change my display name I get the well known error message: You cannot change your Display Name at this time. You can only change your name once every 7 days. I changed my current name about 2 days before the end of last months session. (aprox 2 weeks ago) Admin, could you please look at this and try to fix it, thanks. Changing display name (racename) - drg - 11-17-2005 yeah, same with mine. i changed it the last day of the session adn i am still not able to change it. Changing display name (racename) - JDMAccord02 - 11-17-2005 same here.. Changing display name (racename) - vtec_666 - 11-18-2005 why has this not been fixed yet, the topic about the registration bug did get fixed allmost immediately Changing display name (racename) - rom3o⢠- 11-18-2005 fixed. Changing display name (racename) - vtec_666 - 11-18-2005 You cannot change your Display Name at this time. You can only change your name once every 7 days. Changing display name (racename) - vtec_666 - 11-19-2005 Yes i'm impatiant. But this still has nog been fixed. login: vtec_666 racename: Painkiller Want to change it into: HIDDEN_PKILLER Changing display name (racename) - imported_admin - 11-19-2005 Fixed. Changing display name (racename) - vtec_666 - 11-19-2005 Sorry to reply again. But it is still not working Changing display name (racename) - vtec_666 - 11-22-2005 You cannot change your Display Name at this time. You can only change your name once every 7 days. it's 4 days later, not fixed yet! |
