BUG? - Printable Version
+--- Thread: BUG? (/showthread.php?tid=1256)
BUG? - Rocket - 09-06-2005
I get on and try to dyno and it keeps telling me i have a race pending when i don't so wtf can i do to fix that? please lmk I need to get my racing going...i play this while waiting to reload creds for TS
BUG? - PANDAhumpnMONKEY - 09-06-2005
its been this way for a while now..
if u read the forums at all..
there's 2 billion other posts on this same topic..
enough said here.. this thread needs to be locked and/or deleted Confusedmirk:
so is there a way i can fix it...and sorry for not searching....
BUG? - Blazin_Slovenec - 09-06-2005
from memory if you log out then log back in it usually goes away, i am not sure can't remeber that well. Look through the forums
BUG? - JDMAccord02 - 09-06-2005
Umm my suggestion is to not change the dyno numbers alot
like if its
20
20
20
20
20
try jus going to 23 or 25...dont jump like to 40..im not really sure tho because everyone's is different..logging out works for some...logging off for a couple of hrs and then dynoing works
BUG? - Dragon76 - 09-09-2005
I had it happen to me a couple of times (very random). I got the message that I had a race pending, even though I didn't, however, the dyno still worked. ie the changes I made went through. When you get the message, click the Dyno Tune option from the menu and check the numbers again.
