Warning [2] Undefined variable $awaitingusers - Line: 67 - File: global.php(816) : eval()'d code PHP 8.2.33 (Linux)
Warning [2] Undefined array key "style" - Line: 874 - File: global.php PHP 8.2.33 (Linux)
Warning [2] Undefined property: MyLanguage::$lang_select_default - Line: 4984 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key "additionalgroups" - Line: 6987 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 1 - Line: 1399 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined property: MyLanguage::$archive_pages - Line: 2 - File: printthread.php(254) : eval()'d code PHP 8.2.33 (Linux)
/printthread.php(254) : eval()'d code 2 errorHandler->error
/printthread.php 254 eval
/printthread.php 117 printthread_multipage
Warning [2] Undefined array key "showimages" - Line: 167 - File: printthread.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key "showvideos" - Line: 172 - File: printthread.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key "action" - Line: 140 - File: inc/plugins/automedia/automedia_functions.php PHP 8.2.33 (Linux)
Warning [2] preg_match(): Compilation failed: invalid range in character class at offset 49 - Line: 28 - File: inc/plugins/automedia/mediasites/twitter.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key "action" - Line: 340 - File: inc/plugins/automedia/automedia_functions.php PHP 8.2.33 (Linux)
Warning [2] Trying to access array offset on value of type null - Line: 1182 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Trying to access array offset on value of type null - Line: 1188 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 102 - Line: 1182 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 102 - Line: 1188 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 2723 - Line: 1182 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 2723 - Line: 1188 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 1 - Line: 783 - File: inc/class_parser.php PHP 8.2.33 (Linux)
/inc/class_parser.php 783 errorHandler->error
/inc/class_parser.php 847 postParser->mycode_parse_post_quotes
[PHP]   postParser->mycode_parse_post_quotes_callback1
/inc/class_parser.php 733 preg_replace_callback
/inc/class_parser.php 416 postParser->mycode_parse_quotes
/inc/class_parser.php 177 postParser->parse_mycode
Warning [2] Undefined array key 1 - Line: 802 - File: inc/class_parser.php PHP 8.2.33 (Linux)
/inc/class_parser.php 802 errorHandler->error
Warning [2] Undefined array key 2683 - Line: 1182 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 2683 - Line: 1188 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 1604 - Line: 1182 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 1604 - Line: 1188 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 446 - Line: 1182 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 446 - Line: 1188 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 1679 - Line: 1182 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 1679 - Line: 1188 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 217 - Line: 1182 - File: inc/functions.php PHP 8.2.33 (Linux)
Warning [2] Undefined array key 217 - Line: 1188 - File: inc/functions.php PHP 8.2.33 (Linux)
why 4x HI LIMIT is BAD - Printable Version
+--- Thread: why 4x HI LIMIT is BAD (/showthread.php?tid=5392)
Pages: 1 2 3 4 5
why 4x HI LIMIT is BAD - dnb_Fueld - 08-11-2009
Nate and brett, keep your personal BS to the flame wars. this is a discussion forum,
why 4x HI LIMIT is BAD - rhs - 08-11-2009
that uhh.. 4x rule is crap.
soda guy or pop w/e it is got the win in tha bag
i remember waaay back when there was no limit
people used to wait for you to come online
people would be scared to come online cause they know they'd get raped
now its like.. work work work work and get outta range and your free as a little birdie
why 4x HI LIMIT is BAD - UNKNOWN_NZL - 08-11-2009
I will catch himTongue
why 4x HI LIMIT is BAD - fast_fry - 08-12-2009
rhs Wrote:that uhh.. 4x rule is crap.
I am quite looking forward to the end. Look at all you can get from achievement creds. if you saved just the racing one's its over 60k.
I just hope there are some Hi'rs around to come for the ride.
And if you take the HI limit off then you wont be getting big hits anyway. NO ONE WILL JUMP. There is not need to as there is not 2x xp for the crew and you need QM which how can i get at this range. So every1 will be sitting at 1-5bil nets unless they level which normaly is quick.
All i can say is hit the person at the top of your range when you HI. that would be the easyist way to make your net higher.
why 4x HI LIMIT is BAD - 90teg2 - 08-13-2009
the limit is still bullstank and i only complain about gettin hit to tyler lmao so i gotta agree to it sux!
why 4x HI LIMIT is BAD - bubye - 08-13-2009
i dont like HI limit because i want soda money Big Grin
why 4x HI LIMIT is BAD - fast_fry - 08-13-2009
bubye Wrote:i dont like HI limit because i want soda money Big Grin
You dont need to steal my stuff to come and stay Bubye. You know that
why 4x HI LIMIT is BAD - NoToRiOuS_ThUgS - 08-13-2009
me and shane got paul.....but shane owned him 8 times....lol.....sorry paul...but you know you gotta do what you gotta do to win.....
why 4x HI LIMIT is BAD - Black__Metal - 08-13-2009
NoToRiOuS_ThUgS Wrote:me and shane got paul.....but shane owned him 8 times....lol.....sorry paul...but you know you gotta do what you gotta do to win.....
yea paul ... shane owned you lol
Black__Metal Wrote:yea paul ... shane owned you lol
ROFL
That just shows how litle he thought about it.
Now i will have 2 work again to get my net back up.
= CBR
DUMB CUNT Hahaha.
So now means they have 2 spend a lot more
