Saving credits - Printable Version
+--- Forum: Cars, Mods and Tuning (http://www.midnitechallenge.com/forums/forumdisplay.php?fid=10)
+--- Thread: Saving credits (/showthread.php?tid=4142)
Pages: 1 2 3
Saving credits - D1STURB3D - 03-02-2008
for ww3 you need the best parts and it was a good way to add a part without dyno
Saving credits - QuickAl - 01-27-2009
if you are just in you regular car for racing, I only dyno when i first set up the car. after the initial dyno, i never do it again. when you upgrade your car, all you have to do is uninstall your exhaust, then reinstall it. it may not be 100% pr but it saves you the 10 credits from dyno
going for IDE, I don't know. I haven't gone for that in 3 years
Saving credits - sohc_my_dohc - 01-30-2009
jdawg is absolutely right. i've been using this method to tune my cars for IDE and have showed it to several others members. now officer_cartman i see what you mean when you stated that the % changes after you install each part but that doesnt play a factor because the PR changes accordingly. For example, if i installed a Greddy Turbo kit, if you will, and the pr showed as 245 (87.6%), if you were to use the simple cross multiplication formula provided by the OP you would get 279.68 PR. now if you then install another turbo kit, it may show up as 240 ( 80.4 %) giving you 298.5 PR. now you see givin that the 2nd turbo shows a lower PR before calculation, the % is lower accordingly to provide a higher number at 100%. I'm sure i've lost some of you but trust me this will help save you TIME AND CREDITS. If some of you are confused by the simple formula then I can provide a more simpler way of explaning it. FIRST, you take the PR right after the install. THEN, you multiply it by 100. After you have done so, you take that number and divide it by the % that is given. THEN you should have the PR at the parts value at 100%.
