Warning [2] Undefined variable $awaitingusers - Line: 67 - File: global.php(816) : eval()'d code PHP 8.2.31 (Linux)
Warning [2] Undefined array key "style" - Line: 874 - File: global.php PHP 8.2.31 (Linux)
Warning [2] Undefined property: MyLanguage::$lang_select_default - Line: 4984 - File: inc/functions.php PHP 8.2.31 (Linux)
Warning [2] Undefined array key "additionalgroups" - Line: 6987 - File: inc/functions.php PHP 8.2.31 (Linux)
Warning [2] Undefined array key 1 - Line: 1399 - File: inc/functions.php PHP 8.2.31 (Linux)
Warning [2] Undefined property: MyLanguage::$archive_pages - Line: 2 - File: printthread.php(254) : eval()'d code PHP 8.2.31 (Linux)
/printthread.php(254) : eval()'d code 2 errorHandler->error
/printthread.php 254 eval
/printthread.php 117 printthread_multipage
Warning [2] Undefined array key "showimages" - Line: 167 - File: printthread.php PHP 8.2.31 (Linux)
Warning [2] Undefined array key "showvideos" - Line: 172 - File: printthread.php PHP 8.2.31 (Linux)
Warning [2] Undefined array key "action" - Line: 140 - File: inc/plugins/automedia/automedia_functions.php PHP 8.2.31 (Linux)
Warning [2] preg_match(): Compilation failed: invalid range in character class at offset 49 - Line: 28 - File: inc/plugins/automedia/mediasites/twitter.php PHP 8.2.31 (Linux)
Warning [2] Undefined array key "action" - Line: 340 - File: inc/plugins/automedia/automedia_functions.php PHP 8.2.31 (Linux)
Warning [2] Trying to access array offset on value of type null - Line: 1182 - File: inc/functions.php PHP 8.2.31 (Linux)
Warning [2] Trying to access array offset on value of type null - Line: 1188 - File: inc/functions.php PHP 8.2.31 (Linux)
Warning [2] Undefined array key 28 - Line: 1182 - File: inc/functions.php PHP 8.2.31 (Linux)
Warning [2] Undefined array key 28 - Line: 1188 - File: inc/functions.php PHP 8.2.31 (Linux)
Warning [2] Undefined array key 429 - Line: 1182 - File: inc/functions.php PHP 8.2.31 (Linux)
Warning [2] Undefined array key 429 - Line: 1188 - File: inc/functions.php PHP 8.2.31 (Linux)
Warning [2] Undefined array key 486 - Line: 1182 - File: inc/functions.php PHP 8.2.31 (Linux)
Warning [2] Undefined array key 486 - Line: 1188 - File: inc/functions.php PHP 8.2.31 (Linux)
Warning [2] Undefined array key 512 - Line: 1182 - File: inc/functions.php PHP 8.2.31 (Linux)
Warning [2] Undefined array key 512 - Line: 1188 - File: inc/functions.php PHP 8.2.31 (Linux)
problem with tnt? - Printable Version
+--- Thread: problem with tnt? (/showthread.php?tid=1646)
Pages: 1 2
problem with tnt? - calder12 - 10-13-2005
umm I am sure you all know this by now but tnt to the 60ft, why? because it is the only nearly consistent number. I doubt this is necessary but.....
1) change your tires so that they're new
2) Refill your fuel and tune your car up. Change your oil too if you haven't done so in a while
3) Do NOT use NOS for TNT... if you have NOS, leave it empty when you're TNT'ing (this is a TS thing, we can't buy fuel and nos by the barrel lol)
4) Run the test and tune
5) Start with the top numbers (front tirepressure)
6) Write the Fr tirepressure down along with its current 60' time
7) Change the tirepressure either up or down by 2 (so if the front tirepressure is at 32, change it to 30) and do a run.
8) Write the 60' time at 30 psi for the front tirepressure. If your 60' time is lower than when it was at 32, keep goin' down. If it's gone up, then run test'n'tune again at 34. When you reach your best time by 2's adjust it by one to make it optimal, do this for all settings except camber leave that at 0
For the record all my cars are running consistently after tnting as long as they are tuned up.
problem with tnt? - GODthurisnoother - 10-13-2005
rick
"2) Refill your fuel and tune your car up. Change your oil too if you haven't done so in a while
3) Do NOT use NOS for TNT... if you have NOS, leave it empty when you're TNT'ing (this is a TS thing, we can't buy fuel and nos by the barrel lol)"
thats not like that in mc when tnting it dont use fuel :p mc noob :p
problem with tnt? - Dannyboy1 - 10-13-2005
Duhh, I didn't know we could change the oil in our cars on MC.
I must be oober n00b.
problem with tnt? - Rocket - 10-13-2005
lol got all that down...but it's just odd how it changes so drastically the speed that is...on ideal settings for the car u know
problem with tnt? - LuDe - 10-14-2005
calder is talking about ts thats y
problem with tnt? - calder12 - 10-14-2005
lol, ok I admited to the nos thing, I never knew the fuel or oil thing. Hell you guys know I'm a dumb noob, but ya also know that the jist of tnting is the same in both games. Big Grin
ya...but u own in ts...
